Thermotion electronic coolant flow control valve still working just fine!
Well, after 3 years of using the
Thermotion electronic coolant heater control valve to shut off the coolant to the heater core, I am very pleased with the performance. Having the ability to change the amount of coolant going to the heater core via a rocker switch at the lower part of the dash is so handy. I don't have to stop, get out and turn the valves, I can just press a rocker switch to control the valve. I can get the cold A/C air need out of the dash vents by shutting off the flow to the heater core while still allowing the coolant to flow in and out of the cylinder head as it was designed. Then if I need a bit of heat on a long drive to modulate the A/C temps on a cloudy, rainy day, all it takes is to flip a switch! Convenience at its best!
I haven't taken the time to research the resistance in the temperature slider controls in the dash, but according to Thermotion, they could ultimately be used to control the diverter valve in the unit to modulate the coolant flow to the heater core. I opted to have it either fully open or fully closed when I use my double pole double throw rocker switch for 30 seconds in either direction. I guess I could stop the valve less than fully open or closed by turning off the rocker switch after less than 30 seconds, but that is not the reason for this valve.
I am still enjoying the 36-38 degree air from the vents on Max A/C recirculate during these humid, hot, hazy summer days. Plus, it has not affected the temperatures of the coolant after many times of testing while towing over the 5 mile stretch of 7% grade on I-64 in WV. Glad I was able to fix it relatively simply...
