Cometic hg and cut head compatible
Where to take my truck in St. louis mo
Exhaust Temp Gauge faulty?
I currently have a Fire-ringed head and studs that is two years old. Running 40psi max, I noticed coolant stains above the oil pressure regulator today. If I were to install a Cometic HG and ditch the firering setup, would my head be useable or junk?
TIA,
Dan
Dan - long time no see, man.
Is your block cut for the fire rings as well?
I'd tend to think that you'd need a new head if you're running any HG and don't want to run rings of any kind. Or just use o-rings with the cometic gasket... there's a thought.
Beers,
Matt
