COMP461 said:I don’t believe that they make ether strong enough to start a P-Pump with a big cam , and 60 degrees of lead. .
Guess again, COMP!LOL
Ether is good food.
COMP461 said:... I don't believe that they make ether strong enough to start a P-Pump with a big cam 13. 5 to 1 compression , and 60 degrees of lead. But that same motor would run incredible with that lead up at a high RPM.
Sled Puller said:First of all, dropping names doesn't prove anything. I was talking to John before you lost your gasser ride for poor performance, and tripped into the Diesel world. And how does using Johns stuff make you the innovator you claim to be?.
Sled Puller said:As far as your 9 second run, let me tell about the 3rd base theory. There was a puller that was a leader in his field, but can't buy a win, now. Wondering why, we took a look back at his career. Turns out, when you really look at it, he started on 3rd base, with an infield single, because no one was covering 1st or second.
Now everyones hitting triples and then some. .
first my truck is made of good old Mopar factory steel, still has the dodge parts stickers affixed to the inside of the body panels , the only parts not factory steel are the front end and doors . That is an NHRA requirement for PST , no tupperware here , but you to can own one too if you wanted , , the truck is no different then any other performance power adder , like twins , if you think I have a unfair advantage , even it up and call Bickle, I’m sure he would build you one also.Sled Puller said:Your tupperware truck is on third base right now, after you bunted(500 HP, no biggy. ) because noone else has bothered to do it.
You have reached the HP limits you are capable of scrounging together, so now you are talking exotic stuff, hoping to gain interest, or you just don't quite understand how a Diesel makes 1400 HP. .
Sled Puller said:.
Sled Puller said:Talking about what someone else is doing, or thinking of doing, does not make YOU an innovator of Diesel engine performance, any more than me. .
Sled Puller said:And claiming you have seen data logs for any of the major pulling trucks when you haven't, makes you something else.
jwilliams3 said:Anyone know who won the Dodger game today?
