Many people run "box off". This will not hurt a thing. It may lower your fuel economy as you are not getting any additional timing.
You can unplug the box and remove it. Just be aware the boost fooler will no longer work and you will need to plug your MAP harness back into it's stock location. Also, there will be no buffer for overboost codes and the truck will defuel as in a factory setup.
Dave
