Please help
I needed to disconnect my Comp box so I can visit the dealer and I think I must have messed up somehow.
Here is exactly what I did. I know now I probably should have disconnected the battery but hind sight is beautiful thing.
I have a problem with the transmission shuttling in and out of OD and it was suggested to see if disconnecting the box would cure the problem before having a computer reflash done. The Local service guy actually said he thinks there is a TSB on this problem.
But anyway, not wanting to get grief from the local dealer I disconnected my box only from my truck, coiled up the wire under the dash and thought I would be fine. Well this morning I started it up, the check engine light won't go off and there is absolutely no power. Boost won't climb over 5 - 7 lbs, I couldn't see any smoke and I still have the transmission problem.
Did I forget to something here. Do I need to disconnect the MAP sensor or remove something else along the way.
I thought
all I needed to do was pull the box.
I'm driving something that won't pass an ice cream truck and it is frustrating! Please help a newbie to all this stuff.
thanks
I thought
thanks
