Hey Cold Diesel,on testing your connection with a voltage reading,is a mistake cause the chinsey scothlock that Edge provides may not carry the amps. A weak connection will carry voltage but when the amp load increases the connection may not be strong enough to carry it. From the looks of the wire at the injection pump,that you tap looks fairly heavy . So to prevent intermitant problems SOLDER THE CONNECTION. Merv
