You guy's are putting way to much into this subject. If you want the stupid front bumper then just go get it and bolt it on, if not don't. But don't try and drag all these areas of concern up and pretend your a engineer. I personally don't see wear the heavy front bumper would hurt any of the trucks built in safety functions. The posters before me were correct, the bumper is fastened to the trucks frame and is completely independent of the radiator support, or anything else mounted up front. One thing installing the Buckstop bumper will do is tie the front frame rails together. They supply mounting brackets that are fab'd out of 1/4" steel, these brackets bolt to both the frame rails and the front cross member. The addittion of these braces realy strengthens the front of the truck, it ties both frame rails to the crossmember and then to the bumper. Yes the bumper will probaly hurt who ever it hits, much more then if it was stock. But, isn't that the reason for it's purchase? And yes, I do believe the frame is at risk for more damage in the event of a frontal impact, it has been tied together to form a very solid structure, and while it will provide more protection to the occupants, it will also take more of the load. I for one do not care if the frame gets bent, if I am in an accident I just want to survive with the least amount of personel injury, the truck can and will be replaced.
If you do decide to get the bumper, yes 200-250 lbs of extra weight hung on the front of any vehicle will create more load for the front suspension components to handle. And if you want you front to stay at the same height, you might have to make a few adjustments. After a month or two, when the front end has adjusted to the weight, you might want to switch front shocks, springs, or install a spring spacer, it just depends on the truck and your needs. Most that have bought the bumper, have add another 100lbs by installing a winch hiden in it's front, this may or may not be a route you wish to partake? I did with mine, and really never lost any height. Good luck
