CBari
While changing the oil and servicing my 03 this weekend I noticed a coolant leak. The coolant could be seen on the bottom of the oil filter mounting assembly where it bolts to the block. I at first figured the water pump was leaking again and time to replace it as it has been about 100k miles since it was replaced last. I looked it over and couldn't find the leak originating from the pump. My question is there water passages under the oil filter mounting assembly where it bolts to the block that could be leaking?
On a second note the power steering pump has always seeped some but it also looks like it has gotten worse. Is it better to replace whole pump or just the reservoir as that is where the leak appears to be.
Thanks for the advice.
