Several months ago, Bob Weis started a search for a way to reduce the temperature of the fuel as it entered the VP-44. I followed it with interest thinking it seemed like a good idea! But, when some one mentioned that they gained fuel economy by cooling the inlet fuel, I jumped in with both feet!!!
I have just returned from a 10k mile trip... over 4k towing my travel trailer. I have run in temperatures from the high 20s to 100 degrees. Before I give my observations, let me tell you what I have done to my truck.
First, I relocated my original fuel filter housing to an angle iron base on the frame... moving it slightly down and outboard of the original position. I did it for two reasons. One, it seems to suck a lot of heat off the head where it is originally mounted... making it a fuel heater. Also, since I planned to fun a cooler in front of the radiator, I would have a situation in which the fuel lines would go from the frame to the moving motor, back to the frame, and back again to the motor. By relocating the filter housing, everything is mounted solid on the frame until it enters the VP.
I made my own fuel cooler out of copper tubing with brazed joints. I couldn't find a cooler that fit in front of the radiator, so I made one. Texas Diesel did me the favor of taking pictures of my system and posting them on the original thread. I hope he can post them here as well.
I relocated my fuel return into the tank to the fill tube. While this modification stands to lower the fuel temps slightly, I did it mainly because I run a lot of engine drain oil in my fuel and I felt it would help better "mix the brew".
Relocating the fuel filter housing is the best single modification to lower the fuel temps!!! Some have left it in the original position and insulated it from the head with plastic washers. That would be a simple way to get a big improvement... but it will still move with the motor, which I wanted to eliminate. I also think you will get even less heat into the fuel if the housing is farther away from the head.
I have found that the fuel going into the cooler is about the same temperature as the outlet at temperatures of about 50 degrees or lower. Above that, there is a DEFINITE difference between the inlet and outlet temps! The outlet seems to be about the same temp as the front bumper at ANY outside temp!
I seem to notice a little more noise until the motor is warmed up well from about 50 degrees on down. From about 30 degrees on down, it NEVER goes away. I am not sure why it is noisier or if it is a bad thing.
I was sure I was getting better economy while towing after installing the cooler. To prove my improvement, I disconnected the cooler and ran several hours without it. The economy on the overhead computer dropped exactly 1 mpg!!! I hooked it up again and it recovered the 1 mpg. The economy without the trailer seems to be up about 2 mpg. This thing DEFINITELY helps the fuel economy!!!
One thing I really like about the system is that you can install it and forget it. There are NO moving parts! It was never my goal to have bragging rights to the coolest fuel entering the VP on the planet! I just wanted to make life a little easier for the VP by cooling the fuel... and gain some economy at the same time. I feel the modification is a great success!
I now welcome your thoughts and comments.
Steve Keim
Steve Keim
