Core (Hurst) short shifter NV56
time for new injectors?
Transfer Case Problem
Darkbloodmon
I know the BD Short shift kit has been discussed thoroughly, I've looked through archives already.
My question is if anyone has had any experience with the Core(Hurst) short shifter? It's built assembly drop in. Price point is higher, but I like the details on it's construction. Does the brand reputation still carry with this product?
Just be aware what you are looking at is a Hurst "ball" and everything else is made by Core-Shifters.
I have used Core Shifter's parts before as they offer the wear item, shifter pivot ball bushing cup, for the NV5600. Replacing this $20 part sure tightened up what I thought was sloppy gates. FCA makes you buy the entire shifter. So IMO they are filling a niche market well.
No experience with the actual shifter? If not I might aswell buy it and do a write up on it. I've not seen any reviews or videos for it on the NV5600 since BD has stolen the cake so to say. I've previously bought a new stock shift tower from All state gear, and had to reuse my old stem (I don't know the term for it, its the rod that sits in the housing itself that you thread the longer rod in to) because the one they sent had the wrong angle, I swapped over all the new bushings and just kept that part. It felt a little better, but that may have been just a placebo.
Update on the Core shifter.
I've had a bit of drive time on it before I removed my trans for a clutch. The shifter is very tight in it's feel and assembly It will take some braking in. The throw of the shifter is drastically reduced, and the movement through the gears is a much smaller area to navigate, You don't have to throw your hand over to the passenger seat for 5th 6th or R. It feels very mechanical; there is no question as to what gear you're in when you pull or push it. This is a weird way to describe it but I imagine shifting with it feels close to sliding a blade in-between ribs. You're either in or not, and there is very little play and room for error.
No spacer plate is used during installation of this shifter and because of that there is more engine and transmission noise that you can hear. It's not terrible if you wanted you could use some noise insulation material around the top of the trans or in the shifter boot.
My only complaint is that the return motion isn't the same as the stock shifter where you could slap it out of a gear and it return to neutral. There doesn't feel like there's much preload pushing it back to neutral. But this could be because it's not broken in yet, I've a few hundred miles on mine and I'm not used to it 100%, I used to be able to double clutch down shift on the OEM shifter but it's a learning curve for the movement on this new Core one as you have to guide the shifter with your hand back to N, and the distance to the gears is very short.
Overall I'm happy with this purchase and would easily do it again, this shifter puts the short in short shifter. I'd like to compare it to a BD short shifter but there's no one near me with one. This costs a good bit more than the BD but for the quality of the product I can't complain, It's a very precise and solid feeling shifter that you can row fast with, the construction is is really robust aswell.
I'm not an affiliate or sponsored here is the shifter if you're interested.
@Darkbloodmon did this come with a new "shifter pivot ball bushing cup"? This part alone can tighten the feel of the shifting from sloppy, can't tell if it's 3rd or 5th, to tight.
