My AC has slowly started to stop proper cooling. I just came back from a 8500 mile trip out west. I was working fine until we got back to the south (Mississippi) and it began to warm up.
Here are my readings today with outside temp at 91 degrees:
Low side 35 psi
High side 275 psi
Fan on high, engine at idle, in shade, ambient temp 91
Temp at center outlet 60 degrees. Clutch cycled occasionally.
I think the readings are about correct except maybe the low side might be a little low at 91 degrees ambient.
I also expect it could be a damper problem.
Ideas appreciated !!
Low side 35 psi
High side 275 psi
