cp3 freeze plug is gone, why? how? help!
One Piece Driveshaft for mega-cab ..Help
Found a NEW High HP engine for my '07
cp3 freeze plug is gone, REPLACE?? or NEW PUMP?? why? how? help!
my local shop installed some parts for me last week
one day after the install when the truck was ideling
i noticed that its spraying alot really alot of fuel
i did make it home and its stoped right infornt of my house
later i noticed my cp3 freeze plug was gone
when i looked into the engine bay on pumps left side.
we installed "II cp3 bag of parts" the day before and
i had only driven 150km
what can go wrong? to high pressure?
4 days before that we installed fass 150gph
please help can i just get a new plug or have something been damaged
i dont think i have gotten bad fuel. . or i know all my fuel is good
since i use the same in 2 other cars
but i did put in 10liters from a canister but that was
rated for winter use to and should be good
had some really cold days n nights here but
its like the plug had been blown when it was ideling
when i went into the market to pick up some stuff :-{}
NEED MY TRUCK RUNNING FAST :confused:
Did you install the BB correctly, If NOT thats why the plug pop. It is nearly impossible to put the plug back with the pump on the engine,We have the Plug, if you want it overnight shipping you Must let Me Know BEFORE 8am CST this Morning, You also may call Me @ 763-228-7121 this Morning Before 8am,the sooner the Better.
now i have looked at my pump and yes the ball is gone. .
and so are my freeze plug so new ones i need really hope
my pump is okay it have been running for like 1km after the plug went but maby
10-12km after the ball was lost. .
the odd thing was that i had good power
and dnt feel a think but when
my plug went it wsnt going fast at all
on the way home.
is it just one plug or should i look on somthing elese at
this time?
a local shop looked at some cp3 pictures and is it just a freeze plug or is it something in there? i know that those round plogs higher up is for the pump but if i understood the bosch pictures right is it somekind of spring under them that cant be right! (im not looking on the pistons)
now i got the parts from you tod will install it tomorrow.
industrial injection told me the pump should be junk
but they told me i can give it a try but its most likley
not worth the time...
my question is can i hurt something by doing this?
can the pump blow anything into my injectors if
it is damaged? has anyone blown a plug and just replaced it?
before i removed the fuelline i tried to start my truck and it started fine or better than with my old injectors but the fuel that was pooring out was massive from the plug. . but it sure runs so maby there is still hope for my pump!
starting to get crazy cant get any sleep want at least 4h before i go up and install in the morning and the clock is almost 4 at night here...
have missed my rig but now its warm outside just some below freezing
