For me, the smoke while "light footing it" bothers me. Even very gentle acceleration from a stop will produce a pretty heavy gray haze or black smoke even on low settings. That being said, I could care less about smoke under heavy throttle. Also, driving light footed with Smarty, it makes my transmission shift into 3rd gear by 10mph = very annoying. If I download stock software back in, or if I floor it with Smarty software installed, it will shift great, so it's not the transmission.
If I could suggest anything, I would like to see the power applied more linear with the throttle pedal movement, if that makes sense. I like the low boost fueling, but I wish it wouldn't happen at 1" of thottle movement. I believe this is the main cause of my transmission problem. Other than that I think it's a great product, and it shows alot of promise!
Raychem had a great point. My truck being an 05 has no TV cable to adjust to extend the shifts. The signal comes from the ecm. Is it possible for Smarty to do transmission adjustments?
