Crankcase pressure????
Shake & Rattle
Another pulling to the right . . .
hey Joe D. how much crankcase pressure do these older('95) 5. 9b's usually have ????
my front differential is getting oily from the tube, can feelslight pressure with my finger?
any one else ?
'95 xt cab,slt,4. 10,auto,285 BFG all terrains on Centerline Extreme Billit Comet 3's,K&N,tst 230/605, silencer ring in top of toolbox, boost and pyro in full pillar mt. 159,000 mi and climbing... went to feed the cat and it was GONE !!!!!
I have a bottle on mine to trap the oil. You can always feel some slight pressure coming out, I think it's probably normal since I'm not using any oil worth noting between changes. 53K miles.
Ron
'96 Club Cab 2500 4x4, 4:10LS, Auto, BD Pressure Loc, Mystery Switch,TST 230/605, Cummins Chrome, Mag-Hytec rear and trans covers, Boost, Pyro and trans gauges, Optima Red Tops, All black. Tow 14k HitchHiker triple glide 5th Whl. Also use 9. 5' Lance. NRA Life Member.
I'm not sure about a Cummins,but on a Mercedes-Benz diesel the recomended method to check for a bad valve is to put a pressure gauge to the blow off hose. Anything over 5 psi indicates a problem. 5 psi is more than a slight pressure,with your thumb over the end of the hose you can make it fart,for lack of a better word.
