Hello all, it has been a while. Greetings from Germany
A few weeks ago, I was pulling out of the Garage, and experienced a short episode of the dreaded "Dead Pedal". CEL came on , but suddenly the truck ran fine. Cycled the key three times, the CEL went out Read the codes, and saw the P1692, and then wiht the scanner, read and cleared the P0121 codes. Since the last inspection (TÜV- 3x they run the engine at full throttle for 10 seconds to measure emissions), the truck has been displaying the following symptoms:
1. When starting the first time when the engine is cool, it sounds link the timing is too advanced, i.e., the Starter sounds more under load than norma / cranks slower. Previously, I just needed to bump the starter, and the engine would fire right up. (Both Batteries were replaced a year ago).
2 When hot, I have to crank the engine (ten seconds) or more untiul it starts. When it starts there is a puff of black smoke.
I am planning to clean the IAT (still have not got around to it) and put in a new MAP Sensor.
VP44 was changed by the PO around 40K ago.
More info, while on the scanner I checked the values on the TPS; 00% at idle (not running), 100% on the floor. Pressing the pedal gave steady readings through the scale, not skips, hanging or otherwise.
The truck has over 280 km. Stock engine, put in the Boch 275 injectors around 20K ago. In case it is not in my sig, the truck is a 2001 25000 5 speed. Thanks for your help....
