RWherley
Earlier I had found that my cruise control didn't work work, after checking some wires i found that the clock spring below the steering wheel that lets the cruise wires turn with the wheel eas broke inside and not makeing contact. Now there is a big red sticker on the part that sayes not services able do not open. so i called the dearler and found a new coast $200, so i opened the old one up and what do you know its not that hard to fix. When clock springs go bad all that happens is that the wires inside brake off the base so all you have to do is soder the wires back on. You can take the wheel off fix the spring and put it all back inabout an hour and a half.
