Jim, I cut open the wrapping to my Fluidampr. No bracket or wiring for the sensor. Instructions just say move the sensor to clear the bigger damper.
Stark_Ent9802 said:We did a Valve adjustment tool man one night when you wern't there. It did Help alittle but you can still hear the huffing. I would still would be intrested in doing the gasket, just to see if i had and other internal damege in that engine
JoshPeters said:OK 3 points.
On a gear driven engine, you are talking about how accurate or inaccurate things are by setting your lash and people are saying you have more issues. No you don't. You have MULITPLE gears that not only are set and designed to run in one direction, but they are helical cut(as I recall). One way they walk towards eachother. The way they are supposed to. Backwards and they push away now making the tollerances larger. Why is it that Piers said that you can be off by 4 degrees setting timing on a 12v by gear lash alone!?
If the guy left the lock nut off you can't say it was . 015 out of spec or in spec. Things walked loose at that point. It's all null and void. There is no way to check that spec anymore.
I believe there is alot to be said for accuracy while working on these engines as well. What people don't realize is this is an interferance engine. Things being just slightly off can be catastrophic. Perfect example, the machine shop where I had my head machined said they only took off . 006. They gave me an average. I believe they took . 008-. 009 off the number one cylinder area. Why do I say that? Because while I don't see any REAL damage, I have a perfect trace of number 1 exhaust valve. Will that valve be replaced when I put it back together? HECK YES! It looks fine, no bend. Will I take that chance? No.
JP
PRattenbury said:Jim, I cut open the wrapping to my Fluidampr. No bracket or wiring for the sensor. Instructions just say move the sensor to clear the bigger damper.![]()
TORQUE THIS said:And I'm turning the engine over WITH the alternator!
TORQUE THIS said:BTW... I used the alternator to check the valve lash on #1 intake.
I then barred the motor over according to the pros that are here on this site.
. 002 difference, not a big deal on these motors if you ask me.
ToolManTimTaylor said:255/85R16 (34. 3X9. 00X16) Leveling kit (Tires fit before that but I like the truck level) and 255's will fit on STOCK 2001+ rims 2000 - can fit a 235 stock with no rubbing between the duals <------ SHUTUP TIM or Mark!!!! :-laf
MAleksandrowicz said:That would explain that smoke I was seeing yesterday. That return line wasn't leaking was it? GO COLTS!!!
MAleksandrowicz said:That picture will be gone in about 15 minutes. :-laf
