cummins fuel injector cleaner
Lug nut size?
550 mile run for, "certified," max MPG with winter fuel!
Does anyone recommend the cummins fuel injector cleaner??? Got 100K and have done NOTHING to my truck. OEM EVERYTHING, God where is the wood. . ( Knock Knock)... ... ... . I dont count belts and hoses of course, well steering getting loose, oh and cd player is intermittant, adjusted valves... front rotors are warped... . well i think you get my meaning..... RRR
I have used the Cummins lubricity and injector cleaner additive (red label), it is a good product, and it is over-priced. I now use Stanadyne performance formula, it does everything the Cummins product does and a lot more and it is cheaper in price.
'98. 4 Bright White Quad Cab SLT, 2WD, 12 Valves & the BIG "P" Pump! 3. 54, AT, Trailer Tow PKG, Camper PKG, Cab Lights, DTT VB & TC, Pump Mod's, TST #8, Three pod A pillar gauge mount, EGT pre-turbo, 4" Exhaust Turndown, K&N Air Filter, 5th W. Hitch, Pace Edwards Roll-Top, Tint, 265 Michelins and turbo silencer ring AWOL!
24,576 miles - 3/4/01
I hae also used the Stanadyne performance formula I feel it's worth the price. If yuo go to www.dieselpage.com you can pick up a case of pints for $54. 59 per case including ship and handl, thats $4. 55 ea. Not to bad of price.
95 Ram 2500 slight ENHANCEMENTS!! DEAD CAT, Boost and EGT gauge set, 5 SP, 4x4 trans filter from geno's
I have been having a problem with my 94' truck blowing lots of white/blue smoke in the morning when I start it and was just about to call and buy a new set of injectors when I decided to try adding some of the Cummins diesel additive. Two days later and the smoke is gone. I am assumming that I had a dirty injector that was causing it to leak overnight and would smoke when I started it. I have to admit that I am planning on putting it in every couple of tanks from now on. But, I am also planning on trying the Stanadyne that is a lot cheaper.
Later,
Tim
94' 2500 std cab, 4x4, 12v, 5spd, TST 230/605, 130k mi.
96' 2500 ext cab, 4x4, 12v, 5spd, Cummins Exhaust brake, 65k mi.
IMO the Cummins is OK.
There are other additives that do the same as the Cummins additive plus a little more, and they are cheaper.
I use the LE DCI+. Stanadyne is good too.
