I believe I read that the reason the 24v engines produce less retarding hp. than the 12v engines was attributed to the new head design.
The use of an exhaust brake with an auto. equipped Ram will NOT void the DC warranty. Reference this in a past issue of the TDR (issue 25 I believe).
I feel the BD exhaust brake is superior to all other brakes currently on the market for the following reasons: 1) highest retarding hp. , 2) highest valve opening and closing pressures (the industries largest diameter valve is also least likely to get stuck), 3) does not impose an exhaust flow restriction as some of the other brake designs do, 4) extremely high quality (both in materials used in construction of the brake, additional [supplied] parts required for installation, and factory workmanship of said brake), and 5) adjustability of the idle back pressure which allows one to custom tune the brake to desired levels (within its operational parameters).
I do however, like the ECM integration feature of the Jacobs/Cummins E-Brake as opposed to the BD and Pac-Brake micro switch technology. The micro switch arrangement is good... the integration to the ECM is better.
'98. 5 2500 QC 4x4, (Black) SLT Sport, ISB, LWB, 3. 54 LSD, A/T, Glasstite Vision II canopy, Line-X bed liner, 285/75R16 BFG A/Ts on 16x8 M/T Challengers, Warn 4X Boards, Mopar fender flares, front and rear NW Custom stainless steel/rubber mud flaps, Mag-Hytec diff. cover and trans. pan, Edelbrock IAS shocks, Mopar tow hooks, Jordan Research Ultima 2020 trailer brake controller, VDO Vision gauges, PIAA Dual Sport 900 auxiliary lights and Super White bulbs, BD exhaust brake and TorqLoc, Prime-Loc fuel filter relocation kit, "Scotty Air System", Hitco/Geno's exhaust blanket, Femco/Geno's EZ Drain oil pan plug, Banks Stinger 4" dia. stainless steel exhaust system, plus many other trick modifications
'00 Polaris 6x6
