Joe G. said:I don't agree with larger tolerances making an engine last longer than one with tighter tolerances. I don't think that makes any sense at all.
Joe G. said:I agree with Ryan (rbattelle) about what tolerances are. I don't agree with him that looser tolerances will make an engine more tolerant to environmental changes or wear. Looser clearances will make an engine faster but it will not last as long. Look at race engines for example.
Joe G. said:You are certainly right about the tolerances for a race engine. The guys that are professional builders of those things require that the parts are exactly on spec as far as possible. The clearances, however, can be really loose to minimize friction. That was one big difference between a qualifying engine in NASCAR and a race engine before they made them race with the same engine they qualified with. A qualifying engine would never have made it for 500 miles. If we ran an on road engine with those clearances it wouldn't get very far before we had to overhaul. No chance of getting 100K on one of those. That is not counting the special parts for racing. Take a look at a race engine piston and a street piston sometime. Tight tolerances don't shorten the life of a race engine. Special parts and very loose clearances do. When I used to mess around with hot rods in the '50s we would build a flathead Ford with really loose clearances. It didn't last long, but it hauled butt until it died.
If the torque curve is pretty flat, more BHP for a given amount of torque. Think in terms of the V-10 turbodiesel in the VW Touareg, the BMW diesels available in Europe, etc. Although perhaps not what those of us who tow heavy loads are seeking, the high-revving V-type diesels exhibit operational characteristics much closer to gasoline engines and are, therefore, more accepted by the broad "automotive" consumer marketplace.FANZDSLPWR said:what is the point of a higher revving diesel.
Vaughn MacKenzie said:Here is the latest article on the V6 & V8 development, Sept 2004. The last one I saw was from 2001. http://www.orau.gov/deer/presentati... Light Truck Progress SECOND PRESENTATION.pdf
Gary,Gary - K7GLD said:IF a buyer is PRIMARILY interested in slightly greater accelleration, and a more "car-like" operating diesel, where hard work and heavy towing ability is NOT an issue, then the V-configuration may be fine. But for a hard working TRUCK, give ME a long stroke inline engine every time!
RustyJC said:Although perhaps not what those of us who tow heavy loads are seeking, the high-revving V-type diesels exhibit operational characteristics much closer to gasoline engines and are, therefore, more accepted by the broad "automotive" consumer marketplace.
Gary - K7GLD said:"With all respect, I believe that's what I said. "
YUP - but what *I* was attempting, was to place greater emphasis on what I and some others consider the SHORTCOMINGS of the impending switch to higher reving V-configuration engines - as well as the possible detrimental effects of increasing operation RPM of inline engines - there is likely a price to be paid - and that price may well be in several areas many of us value for our specific use.
It was beginning to look as though some here felt the switch to "bent" engines was all a grand and positive thing - I don't think so! No, not even if *Cummins* is forced into it by environmentalists or other outside forces - the notion that "if Cummins does it, it will be great" vastly overstates reality - after all, GM made "diesel" engines out of beefed up Chevy smallblock engines - Ford marketed the Edsel - and Gm floored the Corvair...
Just because a usually successful major player is involved doesn't assure success or a wise new direction from the consumer point of view...
