curb weight of a ram???
mileage - PHX to Flagstaff
Fiberglass delamination
oops, any mid 90's and up 2500/3500 with a cummins
i would prefer a single cab 4x4 to compare against me. also a 3500 4x4 extra cab drw.
but ill take what i can get... ...
thanks!
a 2004 ram with a 6bt reg cab 4x4 long bed is 400lbs heavier in the front!, i hope i dont dig down in the mud as much as they do!
LAlessi,
Here are the measured weights from my two trucks:
1995, 4WD, automatic, standard cab, long bed, full fuel:
Front axle = 3900 lbs.
Rear axle = 2370 lbs.
Total = 6270
2000, 4WD, 6-speed, Quad cab, short bed, 3/4 fuel:
Front axle = 4240
Rear axle = 2710
Total = 6950
I hope this helps.
Loren
Re: Re: real weight numbers.
Originally posted by John - K5AWO
Didn't you mean 3780 in the FRONT? must have been a typo, darn them keyboards anyway... ;)
kinda depends on the direction of movement doesn't it ?
oops, the end of the truck that has the engine should be 3780 and the square non-pointy end of the truck is 2620.
thanks for helping me realize I've been driving bassakwards oh these many years !!!!
"thanks for helping me realize I've been driving bassakwards oh these many years !!!!"
It's fun to be seeing where you have been for the first time though, :D
Bob Weis
My 97 2wd cab & chassis
Front= 4500
Rear= 3100
Total= 7600
3/4 tank fuel, Ute BullBar, 8x11 flat bed and 5in STACKS.
Not trying to change the subject, but am alittle concerned with the 21,000 GCWR. Specially since the last load I CAT scaled netted 22,100. DOT gonna do anything if I roll a scale over 21k? Maybe I'll start dodging scales. Just the pickup w/fuel grosses 8,300 or some such.
Cheers,
Steve J
I don't think that the DOT has any idea what your GCWR is. It is not posted on the vehicle anywhere.
What they are really concerned about is weight vs. total tire width. I think it's something like 600 lbs per 1 inch of tire width. As an example, my truck (w/o any trailer) has an approximate total tire width of 40 inches (4 x 10"), so 600 lbs x 40 in = 24,000 lbs. That's for a truck with a GVWR of 9900 lbs. Don't confuse this 24,000 lbs with GCWR; the 24,000 lbs applies to the load on the truck. Any load on a trailer is taken care of by the trailer tires.
