Hammer
I understand your disappointment due to the lack of replies,but,when you read the post heading and your initial post I would say its a deal where not many of us run their manifold or that small of a charger. If you would have asked directly for input on II or HTT's turbos or one of the other exhaust manifolds you would have received enough info to wear out your eyes.
Myself,I can not give you any info on the turbos your asking about. I have seen many on the dyno at my clubs shows and unless I'd happen to get a ride in one I could never relate how they drive. I run a Garrett GT37R Stage 3 with a modified and ported exhaust housing and its low end spool up is very quick with the tune on my truck. Its not a cheap charger and alot of people stay away due to its cost,however,it has performed flawlessly for me and I have gotten my moneys worth out of it.
As for exhaust manifolds I run an ATS manifold. It has done a fine job and the only one single complaint I have is the cheap,no thats not a good description,JUNK,temperature coating they use. Not even 3 months after it was installed it was rusting and looks even worse now. If I had to do it over again I would have bought one from HTT direct and had it HPC coated by them. ATS should be ashamed allowing a product which they advertise as "coated" to be so cheaply done and sent out of their shop. I even emailed them and even posted here about their shoddy coating and it went unanswered. They will get no more of my money due to no response to me.
Anyway,I am off my soap box,as for products working well the B-D,ATS and HTT all perform about the same it just depends what your into. Sorry I do not know anything about the D-Tech stuff... ... Andy
