I got mine direct from the web site. I echo DShuart comments. I have the rectangular FP in the cubby hole. Damn near looks stock! and works great. I like the low pressure warning, I have mine set at 4psi. I too think that the teal lighting looks better than the blue. I have had mine in going on a year and have had no problems at all. I used a tapped banjo at the VP to a 1/8npt nipple to a 45deg elbow to a 24inch grease gun hose to the sender. I mounted the sender to the hard brake line coming out of the brake fluid res on the driver side. I just zip tied it between two of the hardlines and have had no problems. Must isolate the pulses enough but let the sender move with the motor enough too. Go figure. I would highly recommend them as a source for digitial gauages.
I am no way affiliated with Dakota Digital, just satisfied customer.
Hope this helps
J-
