2nd Gen Non-Engine/Transmission Dana 60, Help?
2nd Gen Non-Engine/Transmission Front end shot
2nd Gen Non-Engine/Transmission How Do You Clean Your Air Filter?
cgoder
I have a 2002 2500 four wheel drive with no CAD connect. I was in 4 high off rd and something snapped. The u joints are still intact. Stills drives down rd. I put truck in 4 wheel, lifted front axle ,and spin tire freely. I should say lifted only one front tire. Something broke inside pumkin,what? Thanks. :D
Yup, you broke it! Stub shaft, u-joint, half shaft, side gear, spider gear, spider axle, pinion... just to name a few guesses. You just found the weakest link in the driveline. Rich
The front drive shaft still turns. I was hoping I could pull one common part out and fix it. Guess not. I am still under warr. but didn't want to go that route if possible. Thanks Chris :confused:
