DANA Axles
How Much is Too Much?
40ft goosenck trailer lights........
Spyke
Guys and Gals
I was looking at Dana's website and found out this little bit of info
Dana 60F rated 4,300
70BF 5,700
70B 7,500
70HDOS 7,500
70HD 10,000
80 11,500
So I guess my next truck will have a70HD up front and a 80 in the rear
My manual lists my 2500 as having a DANA 60F front axle, and DANA 80 rear. I think the plate on the door lists the front axle weight rating as higher than 4,300. How would that be possible? I may be remembering the numbers wrong. I will look when I go home from work and update this post tomarrow if this still is questionable.
Other note, if the back axle itself is rated for 11,500 lbs then why is the truck rated for a max of 8800 with both axles combined?
Mike
Because the rear axle assy - housing, shafts, brakes - is not the weak link in the system. You've got the frame - rails, spring hangers, etc - and the springs to deal with as well.
Brian
The axles avalible from DANA and the axles on our trucks are not the same. Dodge has dana build axles to their specs. For example our 60f in the dodge has 44 axle shafts and the 80 rear is just an 80 center with 70 ends. A "real" dana 80 is a very different axle. I believe the front axle that Dave Fritz put in his truck from Dynatrack is a full 60. BTW dyna trac actually is not a dana axle they produce their own housings.
