OK I want to keep my Banks Brake so I need to install a bolt up turbo. I have pretty much decided to use a DodgeZilla with a 14cm housing plus waste gate.
So now if I use that turbo I think that I would really like to maximize its potential. This is how my truck currently performs. I would like, as an end result, for the truck to perform at these EGT levels plus 100F. Basically maxing out my EGT at 1200F WOT at any time.
With my current set-up, hauling my camper and pulling my boat I'm running approximately 15k gross rolling weight. I will be going to 285/75 R16 tires and I almost never run more than 60 MPH. Currently, when load, I can pull most any hill with no curves that I have came across at 60 MPH 5th gear and 1100F EGT.
The problem that I have is that I want Mach 4's and but I keep thinking that they could be just too much. They would be fine empty and worrisome loaded. This is even in the light of many threads I have read and people telling me that I "should" be OK. In the end, I want to be able to mash the throttle and not have to worry over EGT's at the same time maximizing my Hp potential.
I'm going to run F1's and so far I have been waiting on funds for the purchase any way. Which is a good thing, because I would probably and a set of each by now.
Please donate to me, your best F1 Mach number recommendation from experience so I can put this in the stern wake once and for all.
Jim
Jim
