Engine/Transmission (1998.5 - 2002) DD III TST PowerMax 3 need boost module?
Engine/Transmission (1998.5 - 2002) Down Pipe Questions
2nd Gen Non-Engine/Transmission OEM hose clamps
Looking for some opinions on my idea. I currently am running 275 injectors & an EZ Edge. I am thinking about going to a TST PowerMax 3 w/ built in gauges (eliminating dash/pillar gauges) & would like to go w/ DD Stage III. Do I also need DD boost module for this setup?(I'm confused whether the boost mod is required or an option) Also, am I heading in the right direction for more power, or should I consider a different set-up?
Thanx for any advice!
brett
Nope, the TST has a boost module already. The PM3 and DD3's will be hot, darn hot. Power will be OMG:eek: :eek: . Lots of fun though. Go for it.
I can tell you from experience that unless you are planning on a turbo upgrade that you will have way way too much fuel. You will be able to peg the pyro in seconds. May as well just get the TST box (or a comp) and save your $ as you will not be able to use the extra power from the injectors anyway.
JMHO
