The default setting on the DD TTPM is setting #3 as I stated before. I also received TWO DIFFERENT units directly from DD set this way however, as this is said to be different on at least one unit this should be checked prior to installation.
The latest DD TTPM I received (TTPM #3) was setup and shipped directly from Edge Products... I thought I made that clear too. New TTPMs will have the LATEST programming which eliminated my lopy idle (for reasons I've already posted). The latest programming from Edge Products NOW USES TWO JUMPERS in the TTPM (I believe the EZ still only uses one jumper though). This is an extremely recent programming upgrade that was made to both the Edge EZ AND the DD TTPM... just a small tweaking. I have ALL the double jumper settings at home however, as stated before, my latest DD TTPM (I received directly from Edge Products) came with the jumpers at #1 and #3 which equals the "old" #2 setting in the TTPM (which equals fueling in by 20 psi boost). As you can imagine (and should reasonably expect given the expediency in which they dealt with this problem), the installation instructions were not upgraded yet to reflect the new double jumper settings (in my case). As I stated before, I received the first DD TTPM with the upgraded program. In fact, I called Keith at DD to give him a heads up regarding the programming enhancement as well as to bring him up to date with the elimination of the lopy idle condition I was experiencing. Both Edge Products and Diesel Dynamics treated my very well while working throughout the entire problem I was experiencing... and I WILL be a repeat customer. Thanks guys!
cullyguy, note the EZ settings below:
#1 = fueling in at 3 psi boost
#2 = fueling in at 10 psi boost
#3 = fueling in at 20 psi boost
_____________________________________________
UPDATED DD TTPM settings (ONLY IF your module came with TWO jumpers):
JUMPER POSITIONS = OLD PROGRAM SETTING
#1 & #2 = #1 (timing only)
#1 & #3 = #2 (fuel in by 20 psi)
#2 & #3 = #3 (fuel in by 3 psi)
[This message has been edited by John (edited 04-08-2001). ]
