DDIII's + EZ, with hx35 = ?EGT
Blew a fuse changing the oil??
TSB website
<font color = blue>
Doug, check the sig file below. You won't be disappointed with the Bill K mods. #ad
I am running the exchange HX35/14cms housing and speaking from personal experience, I just finished an 8,000+ mile trip down I-5, then I-40 coast to coast and beyond, up and around to New York from BC; The first 3,000 miles empty and the rest with my slide-in camper with a total weight of 12,500 lbs.
Peak EGTs never went over 1275 deg F and peak boost registered at 25 pounds. At all the higher elevations, it was much easier to push the envelope, but with a little care, you can still have fun #ad
BTW, I am running federal emmissions and have seen very little smoke (so far) when heavy on the go pedal.
The only problem you'll have is the rush!!
JMc
2001 Flame Red Sport 3500 QC, 5. 9L 24v Cummins, 4x4 Auto, 3. 54/LSD, 155 inch WB, Agate leather, HX35/14cms turbo, Bill K. VB,TC & "smart" PAC Exhaust Brake , Mag-Hytec transmission & Diff covers, SPA Dual Gauges,DD2s,DD4" exhaust, Rickson 19. 5" wheels, Roadmaster XX,Firestone Airbags, WAAG sidetubes with dually kickouts, Line-X, Grovers , Lance 1130 slide-in Camper, 60 gallon “stock” Aerotank, RS9000s, Reese Titan class 5 hitch. plus the ICE-bomb
OK guys,
Need some help... . I have a 2001. 5 that has an EZ installed. I will be doing DTT vb and tc in the next 2 weeks. I then want to add DDIII's, but I know the hy35 that is on the truck is not up to the task. Does anyone have the same setup with a hx35 turbo? If so what are your egt's running?
I am not really sold on the hx40. I also don't do much if any towing (if I do it is only a 3ooolb boat). I looked at BD's hx35 with a 14cm housing but it runs $1000 + I am not sure it is going to be much better than a standard hx35.
Any help that you can give is appreciated.
Thanks,
Doug S.
Took a ride in Lawrences' blue demon about a week ago. That truck was setup with the DTT TC and VB, as well as DD2's, the TTPM and an HX-40. That thing flat screams!
I didn't think the DD2's and a box could support an HX-40, but Lawrence proved it to me. He said that when you have a TC that really puts the power down and offers good load to the engine, the 40 is a great way to go.
For the same money ($1000 w/tdr discount), I'd go with the HX-40 on your setup. Good luck.
I have DD3's and the DD EZ box on my ETH with the HX-35 (until I finish my HX-40 install hopefully today).
EGTs are very manageable at sea level, but you can get over 1300 deg. pretty easily, so you'll need a sharp eye on your guage, or a warning light.
I was able to tow (19k lbs GCWR) up a 6% grade at 1260 deg. at about 65 mph in 5th (2500-2800 RPM). The HX-40 would have been nice to accelerate up that hill, but I had to settle for simply being slight faster than most of the cars. #ad
Rob
2001. 5 RAM 3500 QC 4x4 ETH/DEE Silver/Agate, 4. 10, USGear OD, Rickson 19. 5 Wheels, DD EZ, DD3 Injectors, HX-40, Southbend Clutch, SPA Guages, Psychotty, Firestone Airbags, Hellwig Rear Swaybar, Torklift Superhitch & Camper Tiedowns, Mag-Hytec Diff Cover, DD 4" Exhaust, US Gear Exhaust Brake, etc.
