This has probably been talked about a thousand times but I was tired of searching through hundreads of threads not relating to my question.
I have a 2002 HO with a Edge EZ, Straight Pipe, BAHF, w/ a SBC and gauges on the way.
My question which would be better as far a power and realibility goes? I an leaning twards the 3's. Would 3's w/ a EZ make more power then 2's w/ comp? I dont want to buy a new turbo so the comp and 3's are definetly out. Will I need a new turbo using the 3's w/ EZ.
Rebember the ETH doesnt respond as well as the ETC with bombing power numbers. I also heard you should run bigger injectors with the ETH.
