Pulled the 370s, and got the new injectors in last night.
Only driven about 60 miles so far, but I'm VERY impressed with them. Great power, and considerably cleaner than the 370s. White haze at idle is gone. Unless I lug the engine, or plant to go pedal off the line, the smoke is minimal, other-wise, I can still black out both lanes.
Before advancing my timing (and with the 370s), I was seeing 45# boost and up to 1400* pre-turbo, even empty. Advancing the timing reduces peak boost and lowers EGTs. Now, so far with the DDP4s, I've seen a max of 40# amd 1200*, with more power.
I'd say 370s are cheap power for the money, but if you can swing a set of extrude honed or EDM injectors, you will be better off. More power, less heat, and less smoke.
We'll see what the mileage does now.
