DDT tc/vb
~Mini-Me Adventure with Ricky Carmichael~
is kerosene safe to run in a diesel?
Hi,
I'm a new member to the TDR and am going to order the 91% DDT tc and vb next week. Is there any other transmission parts that should be installed at that time? I have a 98. 5 w/52k miles on it.
I will work on my signature as soon as I can get back to that page.
Dan, It would be worth your while to make the trip up to Abbotsford for your VB & TC
installation.
Bill's Crew is A1
Take Care,
Bob
PS Welcome to the TDR!!!
What he said ^^^^^
Jack
2K, 2500, Quad, SB, 4x4, 3:54LSD, A/T w/ DTT VB, TC, TC SAVER and AUX COOLER , REESE 15k 5th slider, EASLEY BULL BAR, MAAP NERFS, BFG-TA's, 9000's,TORQUS MAXIMUS 505 lbft ECM, stealth DD2's, Bully Dog Boost & elbow, ISSPRO pyro, boost & transmission, Turbo Lifesaver, JARDINE 4", PAC BRAKE, MAG HYTECH TP& DC, AFE filter, GEAR VENDORS OD, TAYLOR WING, MAGNA MIRRORS onboard.
pullees:
#1 y2k ARTIC FOX 5th
#2 22' car hauler w/ 76 Pinto 392cid or 68 Cyclone GT Cobra Jet FB
NRA-LIFE, VFW-LIFE, SoCSA-LIFE, SASS
Thanks,
I have found a shop in Porland that Bill has talked to and he thinks they will do a good job. But the real ??? is there anything that needs to be done to the transmission while it's out, since there is 52k miles on it?
Bright Red 98. 5 2500 4 X 4. 285R75 16 2"lift in the front to level it out with a 8264 Warn wench. Hiway aluminum 5th wh. tool box. 32'Alfa 5th wheel w/2 slides. 1 pair of black truck nutz under the rear because it's a RAM not a ewe. K&N air filter,soon DDT tc/vb
Dan,
The transmission guy should make the normal pressure tests before it's pulled. If they are ok you're in good shape to just do the install.
Joe George
Eureka, CA
'95 2500 CC auto 4X4,3. 54,Combo EGT/boost guage,custom switch panel,PacBrake,TST #5,DTT TC/VB,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver
Hey Dan,
I just got mine done. Im in the southern part of Oregon. I had mine installed a couple weeks ago by a shop in Redding, which is about 6 hrs from you. I called that guy in Portland (or was is Salem?), he did not impress me at all with the first conversation. Plus the guys in Redding did alot better price and a bunch of extras. Might be worth a trip for ya.
2001 QuadCab,SWB,Auto, 4X4,4" Flowmaster Raceing Exhaust, DTT TC & VB, EZ Box, Bosch 275 Injectors, Mag-Hytech transmission pan/Dana 70, K&N, 33" BFG AT'S... ... .....
Dan... .
welcome to the TDR.
Bob and Jack are right on.....
IMHO, you're too close not to find a way to go to Bill for this. You'll have a great time and never meet nicer people. When Darin or Vinnie take you out for the final road test you won't believe the magic these folks weave... ... sorry, didn't mean to get sappy. ;(
I live 90 min. south of you, and would take this trip again in a heartbeat. No disprespect meant for any other installer.
In any event, you'll love your new truck.
White 2001. 5 2500 ST, SWB, 4X4,QC, AUTO, 4. 10's, LSD, 285/75/16 On Weld Outbacks, PIAA 510's, Line-x, Tinted glass, Redline 85+, Blow-by-bye, RE-0880 & 25-0880,muffler fell off,level truck with 2" tuff country kit, Bilsteins at the corners, Di Pricol egt and boost, Mag-hytec "original flavor" transmission pan and Dana 70 diff. cover, Westin Step Bars,DTT TC/VB,yeee-ha,EZ, Custom Plate 24V-DSL
Hey Dan, do yourself (and your Ram) a favor and have Bill and his select crew perform your transmission upgrade. It's really not that far from Tigard... and the job you will receive will be unmatched by anyone. #ad
John Treibel
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps and accs. , Mag-Hytec diff. cover & DD trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, SPA gauges (3), Dynamat, '00 Sport grille and headlights/PIAA Super White bulbs, PIAA Dual Sport 900 aux. lights, BD exh. brake, Amsoil Dual Remote Bypass w. trick billet block adapter and Aeroquip Teflon-s/s hoses, Optima Yellow Tops, DD3s and DD TTPM, Aeroquip AQP s/s fuel hoses, tricked out Cummins valve cover, tricked out Banks High-Ram intake manifold and 14 cm2 turbine housing w/Big Head wastegate actuator, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , DTT 93% TC, DTT custom tuned VB, BD modified trans. front pump (enhanced by DTT), Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
NRA Life (Patron) member
I just had mine done by Clay Carrington in Morgan, UT and could'nt be happier. You may want to consider putting in the '95 cooler line w/temp sensor if your thinking of a trany temp gauge. Having a Dodge dealer do the transmission work is great. He spotted a input seal leak and changed it out under warranty. I supplied the fluid, cooler line and sensor and four and half hours later it's done for $405. Can't say enough about Carrington Motors.
'98. 5 2500 QC ISB 4x4 SLT, Auto DTT TC & VB, JRE 4" exhaust w/5"Tip, DD II's w/Module&Elbow, VA box, Rancho 9000's w/in cab adjust, Mag-Hytec trans&diff covers, Jacobs E-Brake w/BD autoloc, trans temp, boost & EGT gauges, 2Low Kit, Air Horns, Catz MSX, Drawtite Front Hitch, Brite Box, Steel Horse Billet Grilles, AirBullDog hood induction system, Brandon's stainless steel fuel lines, Intake heater system saver
From what i understand the 93% is more aggresive in shifting and is recomended if your going to do serious bombing, I got the 91% that bill recomended. See my mods. I think most people get the 91%
<font color = blue> Dan, I can only reiterate what others have already said before not only in this particular thread... . being this close to DTT is your perfect excuse to determine your preferred installation location... . you may have to wait a bit longer for a mutually convenient slot in DTT's schedule #ad
though.
I made the round trip myself from Europe, which was a no-brainer for me.
BTW, get your gauges installed before and not during the VB&TC install - Bill won't want another Deja Vu experience #ad
JMc
2001 Flame Red Sport 3500 QC, 5. 9L 24v Cummins, 4x4 Auto, 3. 54/LSD, 155 inch WB, Agate leather, HX35/14cms turbo, DTT VB,TC & "smart" PAC Exhaust Brake , Mag-Hytec transmission & Diff covers, SPA Dual Gauges,DD2s,DD4" exhaust, Rickson 19. 5" wheels, Roadmaster XX,Firestone Airbags, WAAG sidetubes with dually kickouts, Line-X, Grovers , Lance 1130 slide-in Camper, 60 gallon “stock” Aerotank, RS9000s, Reese Titan class 5 hitch. plus the ICE-bomb
[This message has been edited by JohnMcIntyre (edited 05-09-2001). ]
Can someone post the advantages to having a 91% verses a 93% TC installed? What about lock-up speed disengagement? Is 37 mph a good choice?
Thanks! Dave
Yeah ... ...
2001 RAM H. O. 6Sp 2500 SLT 4x4 Quad Cab, 4Wheel Disc, 4. 10 Limited Slip, Fog Lights, Muffler removed, Silence Ring Gone, Autometer Pro Comp 60# Boost & Pyro, Banks High Ram (Red), Cummins Red Valve Cover, K&N RE-0880, Skyjacker 2. 5 lift Class 2, 7218 Dual steering stabilizers, Custom Pro Fab Trackbar (sweet), EGR Flares (nice fit), Centerline Comet III 16x9. 5 with Goodyear MT/R 315/75R16, Smittybuilt stainless nurf bars, ExTang BlackMax tonno, THIS IS NOT A HOBBY, THIS IS AN ADDICTION !!! MAINLINING DIESEL !!! "I AM GLAD I DID NOT BUY AN AUTOMATIC, JMO"
Before DTT I would go into OD at around 40-45. Now its between 50-55. Which is perfect for me now because at about 60mph my rmps are at about 1600. Before (stock) it was way to early.
