I've had in the plans to upgrade the turbo. Just been waiting for the funds to catch up. I'm sort of thinking of whether or not it would be worth it though.
I can't tell a whole lot of difference between level 3 and 5. I've thought for a while now that it's because I don't have enough cool air to mix with the fuel on level 5. I know most of you would say thats a given with the HY, BUT
My Specs:
Alt 950ft, WOT on 5-5, 38psi boost, 9psi fuel and 1450deg max egt. I tow and haul light loads sometimes, but have never had a problem with EGTs.
After looking at the DD HP graph on their website, I'm not so sure I should be seeing THAT much more power from 3 to 5, it seems to be the same if not less than the jump from 2 to 3.
The majority of the reason to upgrade a turbo is to get the EGTs down, right? The other portion is to get more volume of usable air/fuel into the cylinder.
If I am not having a problem with high EGTs with the HY, would it be worth 800 to 1600 bucks in order to get another (I'm guessing) 40-60hp.
Or am I way off.
My Specs:
Or am I way off.
