Engine/Transmission (1998.5 - 2002) Dead player 99' w/comp box ??
Andy,
I was on the accelerator passing someone, at the same time I was turning up the ProComp. The engine bucked once, then the "Check Engine" light came on and it shut down. I could not get it to re-start. I have fuel pressure (lift pump), but it simple won't fire up. The Comp box still "appears" to be OK, I can turn it on and off and change levels. I don't know if I tripped an over fuel code or what, but now it acts like the ECM is not telling the pump to inject. This is with box on or off. Any ideas? 99 Dodge 24V, Edge ProComp, stock injectors, K&N FIPK Gen II, Autometer Boost, EGT, Fuel Pressure Guages.
Mike
This is a buddy of mine and the truck is at the dealer now. I think they can be trusted to check it out. We would very much like any thoughts on this or similar sounding problems.
Thanks in advance,
Andrew
