grabinov
Ok Gents,
I swear it wasn't me. A buddy with a 2016 2500 just accidentally put half a gallon of DEF in his fuel tank. He called me when he realized it. It's in his driveway and he hasn't started it. So:
DEF is 67pct water, so diesel fuel will float on top of it - his fuel tank is full (now full of fuel and DEF, LOL). That means that if he lets it sit overnight, the DEF will find its way to the bottom, presumably right where the fuel pickup is. What to do next.
One idea is to remove the inlet line from the under-bed fuel filter and then attach a hand pump to the line (like the bulb used on an outboard engine). Then "crank" the pump to suck fuel through the factory fuel pump n the tank until the DEF and some fuel are sucked out. Anyone know if this will work?
Next idea is to do the same but use the factory fuel pump to move the DEF and then fuel by cycling the fuel pump with the ignition just as you do after a fuel filter change. I don't see any reason this wouldn't work.
Go to dealer and let them do the same only they would cycle the pump on with a scan tool.
Go to dealer and have them drop the tank and drain everything out.
The tank doesn't have a drain plug I suppose? Not that I ever noticed. That would be as smart as putting one on a transmission pan. Why would they do something that smart at the factory when it costs an extra $1.50...
ideas?
ideas?
