Hi,
May I once again impose on all you knowledgeable owners of this marvelous machine?
I have a 2017 2500 RAM that I just purchased with 41,000 miles on it. I've been reading about the issue with water pump failures and not sure I have a defective water pump or not. While it's not leaking, I'd rather change it before failure - either have the dealer perform the repair while still in warranty, or change it myself.
After researching the vehicle service history that I got with the truck, the water pump has never been changed, or at least inspected. From what I've read, if I have a vent hole in the casting at the 11 o'clock position it is a good pump. I looked at the water pump itself and am not seeing one. Is the information that I read about the vent hole accurate, or are there any other distinguishing features between a good pump and a bad pump?
The pump casting itself has this part number stamped into it: 4S1021/01. The pulley on the pump appears to have a large AC stamped into it. Does this provide a clue?
I've attached a photo of the installed pump.
Does this provide any insight?
Any and all information much appreciated! Thank you!!!!!!!
Mark
Mark
