Delta fuel tank cleaning
Good deal or no
Final Aux Fuel tanks in bed.
About 2 months ago I purchased a used Delta 105 gal L-shaped fuel tank with a pump for $350 bucks. After I got it home and started to take a look at it, there was a lot of rust and sediment in the bottom. Probably because the PO did not have any pipe dope on any of the threads. I called around to see if anyone cleans this big of a tank. I found one place that does so I took it to them to have it cleaned. This was on the 13th of May (last month). I was told it would be 2 weeks. I said no hurry. They had to drill two 1/2" holes in the front near the corners in order for the chemicals to drain out. The cost of this to be done is over $400 dollars. I have not received any calls stating that it is done. I was talking to my one neighbor and he told me the 1/2" holes make sense if I have to drain the tank again. I sort of agree with him. I can have a couple of nipples welded onto the tank and put a couple of plugs in. Would you guys have this big of a tank with nipples and plugs in the bed of your truck? I am not sure I will have the clearance in the bed if the nipples are on the tank. By the way, I have not paid for the tank to be cleaned yet. If I do get the call I might just not even bother to pick the tank up. According to my copy of the work order anything not picked up after 10 days will be sold. Thanks and I would appreciate any input. Sorry for such a long post.
Rather than a nipple I would probably have a bung welded on and install a plug. Less chance of getting hung up on something If they are drilling the holes I would certainly think they would be responsible for plugging it back up?
yeah you would think they would weld it back up. But there policy is they do not weld. My other neighbor is a semi-retired pipe fitter so I could have him weld on the bungs for me. Already talked to him and said no problem.
