There are, or were, two versions of electric lockers on the market. One, the Eaton E-locker,
ELocker Differentials is strictly open or locked, depending on where the driver sets the switch. Just like an ARB, but without requiring compressed air.
The other is a limited slip all the time, and fully locked when activated. The limited slip is supposed to be smooth and transparent enough for front axle use.
Electric Traction Lock - Tech Articles - JP Magazine
As I recall, Eaton made the first one I described and the makers of the Detroit Locker, Tractech, made the second. But Eaton bought Tractech a few years back, I think, so I'm not real sure they are offering both styles still.
I could be wrong, but that's what I recall from some locker vs. limited slip investigation I did a couple years back when my Dodge's factory limited slip left me stranded and stuck one too many times.
The Tractech (Detroit) version was very interesting because a full-time limited slip with optional full-locker capability would not only
get you out of trouble when combined with a Detroit No-Spin Locker in the rear axle (true, fully locked 4 wheel drive on demand), but it would help
keep you out of trouble in the first place before you lost your momentum with the full-time limited slip up front.
"Full-time" meaning only when you have 4 wheel drive engaged, of course.
The other "money is no object" dream team combination would be a Detroit No-Spin in the rear and an OX or ARB up front. I like the OX design better. They cost the same, and all 3 offer no-compromise, true 4 wheel drive.
The thing about all lockers
except the Lock-Right (light duty cars and trucks only and not very reputable), PowerTrax (much better IF you have a strong factory carrier to begin with), or a Detroit No-Spin (unless you have a GM Corporate 14 bolt), is that they require paying a shop to set them up. Unless, of course, you happen to be one of the few individuals with the expertise and tools needed to properly set up rearend gears.
That holds true for all limited slips, too, unless your's came factory, of course. But aside from an Auburn or Torsen (think Hummer), all limited slips have clutch packs that WILL wear out. Lockers don't really wear out. They either work or break. It is the "slippage" in limited slips that wears them out so fast.
News Flash: It looks like Auburn Gear is now offering an electric locker, too. Here's some comparison info on available electric lockers:
Products | New Products
