I have a 2003 Ram 3500 5.9 that just had an engine install but having an issue running need help! It is a 4x4 automatic with a 47re transmission. The engine was originally a 305 (correction it was a 250 SO) block with a Bullydog. The engine I had installed is a 325 with coated pistons and 12 valve rods for strength. I put a new Industrial Injection Turbo on it new TDM 80HP injectors with Bosch OEM connecting tubes. I hooked up the bully dog to make sure it is in stock mode only. The truck starts right up but has black smoke at idle and dies after about 3 minutes. If I hold the throttle above 1500RPM it will stay running. In the video it looks like white smoke but its black. I have also attached a video of a data stream from my Actron OBDII just in case that helps. The current codes are (6: Driver Squib Open/ this code was there before the engine install) (25: Left Front Circuit Malfunction) (21: Right Front Circuit Malfunction) (84: Mismatched Vehicle Identification Number) (P0107: Manifold Absolute Pressure Sensor Voltage Low) This is the only one that I think is related to the issue. Things that have been done to test. 1. New lift pump with sump installed and does not lose low fuel pressure. 2. FCA swapped out. 3. Rail pressure sensor swapped out 4. Map sensor swapped out.(the one on the manifold not the IAT sensor on the intake tube by the air filter) 5. Injectors and connector tubes removed and re-torqued according to the ft lb's in service manual.
Will put the links to the videos on as soon as the website will let me. it is on Youtube if you search
2003 Ram 3500 5.9 cummins stalling diagnoses issue HELP
ADDED
The engine I got was a brand new long block 325 and ONLY long block no sensors, no turbo, no electronics just the block and head. Everything from my truck was transferred to the new block and head including electronics and harness. EXCEPT turbo, injectors, and connecting tubes. I bought an industrial injection turbo specifically for a 2003 and injectors for a 04.5-07 to match the piston bowls in the 325 block.
Here is the video of the truck running
https://www.youtube.com/watch?v=Cm__mDSUzMY
https://www.youtube.com/watch?v=h4-gyJvPCw8
ADDED
