I've got some Gates SAE J30R7 that I am using. I am using it to run line from the fuel filter to the VP44.
My problem is that I am trying a little mod on my Max Flow Kit. One of my compression fitting developed a leak. So I removed the S. S. braided line and the compression fittings. I am now using a rubber line in its place. But the the ends on the fittings that are still on the truck are not hose barb ( which they were never meant to be anyway ), and I'm having a leak problem on the VP44 end. Even though they are not hose barb ends and they are just a smooth end, I would think that I could tighten a hose clamp tight enough to seal up to 16 psi. What Gives ????
Jeff
