Yeah, this has probably been kicked around here before - and appropriate pointers here or elsewhere are welcome - Wayne-Amsoilman, like to see your comments.
It's like this - we just bought a used motorhome with a GM 454 big block gas engine, and as with my Dodge/Cummins, I want the best possible lube for use in this engine that already has nearly 60K miles, but starts and runs great.
I'm very satisfied with the DELO 400 CI-4 Plus I use in the Cummins - but is the diesel lube formulation and slightly high viscosity an issue in a gas engine in MH service? My next choice would be whatever Amsoil product is recommended as best for this sort of heavy duty use in a gas engine with this mileage - my own past experience - regardless of what Amsoil or their reps say, is that the synthetics tend to "find" leakage spots in older engine gaskets that probably were NOT an issue with the dino lubes - so will religiously go over all accessible gaskets to tighten them up a tad to head off that problem, if the synthetic turns out to be the best way to go.
So, lets hear whatever you guys have to say on either the diesel lube in a gasser, OR your on views on performance of lubes like Amsoil in the same service...
