Diesel_Dan: FASS passed the 5 gal bucket test, what's next
Please Read this. Diesel_Dan works for DPP.....
Torque Tube Problems.....
Diesel_Dan: FASS passed the 5 gal bucket test, what's next?
I PM'd you and you responded to me on one of the other sites (recommending the bucket test), but basically my problem is this:
I bought a FASS 150 in January. I was impressed at how quiet it was since everyone claimed how loud they were. All was good until last month when the pump started cavitating. First a little at a time, now it's pretty much constant. Pressure fluctuates about 2-3 psi up and down (20-23) and the volume of the squealing changes.
I took my truck to a local diesel shop, paid them 3 hours to diagnose the problem at $70/hr.
They put a clear line on the discharge hose and pumped the fuel into another tank. No bubbles, and the pump would run quietly until a kink was intentionally placed in the hose to give a little resistance. As soon as pressure built up, the pump started squealing. Still no air bubbles.
They then dropped the tank, checked the connections and fittings, lowered the pickup tube. No leaks according to them, so they buttoned it up and it's back on the road. It still squeals, and the pressure fluctuates.
What can I do to fix this issue? I find it annoying and I will fix the problem. I would rather keep the FASS than replace it with a competitive product.
The FASS I have has a later production date, but it is not so new as to have the new motor and relay.
Thanks.
I have noticed the same thing with my 95 but didnt think much of it. The pump is louder at some times that others and fuel pressure fluctuates a few lbs. I will keep an eye on this thread to see what develops. I'll also be more than happy to answer any questions if i need to also.
Mine cavitates from time to time... I thought that was normal without installing a larger pickup in the tank? Mine ususally does it at and below 1/4 tank...
steved
steved
I do have the larger pickup. One of the drawbacks of the new pickup is that I can only go to 1/4 tank before my fuel pressure will drop to 5psi, then swing back up to 20. Bottom line is that 1/4 = Empty. I have a 25 gallon tank now. It doesn't make much noise when it does this. The squealing cavitation is pretty much constant now, regardless of fuel level (over 1/4).
The pump was nearly silent in the beginning, just a little whir you could hear when the motor was off.
With the larger pickup, it shouldn't do it at all... from what I have read, that was the supposed cure for the cavitating FASS??
Are you sure it's cavitating? I almost wonder about bad bearings and while it might pump fine under a "no load" condition, as soon as it has a load applied, things get out of wack??? Maybe?
steved
When I think about it, you may be correct. It kind of sounds like a computer fan when it's worn out, but super loud.
I wonder if that's a warranty thing? I'd hate to pay more money to have the thing swapped out and find out that's not the problem...
Dan,
My fass pump has gotton really loud also , sounds like a really bad vibration and does it all the time. Even if the tank is full or half empty. Now my fuel pressure stays around 16 psi. @ idle and cruising. WOT drops to 14 psi. I had the fass with filters that made some noise but not like this one. So do i have a problem? I was about to call my installer when i seen this thread.
Thanks,
Ed
Dan, I called you earlier in the week on the high pressure 12V 45PSI unit, it looks like I have an intake issue, my clear line that used to be clear is discolored, so I thought it had fuel in it. I am pulling the bed off this weekend to examine the intank issue. Did you get the serial numbers for the other Fass units yet? I want to make sure the warranty gets squared away on those. Thanks for the quick response.
Dan
