I just swapped my 885 pump out with a 887 pump and the 887 pump had a fuel solenoid bracket that was bigger and my solenoid would not fit in so i just swapped brackets. now if i put the solenoid in with both bolts it binds and wont come up but if i just use one bolt then it works and the other bolt hole is about 1/2 inch away
are there two different solenoids that these trucks had if so does anyone have the part number for the two different ones
thanks
Ken
thanks
Ken
