Dings and P0514
Brake Actulators
Question for you 24 valve guys 2nd 3rd gens
Turbo1Ton
So I'm driving down the highway last night (been running like 25 minutes or so) and out of nowhere the truck dings. I immediately looked at the gauge cluster to see if there was a warning lamp on. No warning lamps or anything come on with it. So I file it in the back of my mind. Drop my wife off at the house, go to get fuel. City streets running 40-45 mph (approx 20-25 minutes after the first ding) and I get a double ding. Again no lamps. This is just before I get to the filling station. So I get there and I check the codes and I have a P0514 (Batt. temp sensor-right?)code come up. Odd, I'll have to look that up I say to myself.
So, anyone else ever get a ding and no warning lamps? How about a double ding? From reading past posts I thought that P0514 threw a CEL? Maybe not? Maybe I have had that code for some time and it never threw the CEL and I am just now seeing it because of the ding. Could this code cause a ding? And finally, why would I throw this code while driving?
Any ideas?
Jeff
So is the 'lamp out' indicator just a ding? I was under the impression that there was an actual indicator. Although if it was simply a loose connection I suppose it might ding and not light up.
I'll give that a check. Thanks for the suggestion.
Exactly. It'll also work the other way. With a solid indicator light, it'll ding with no flicker.
Make sure to look closely at the thin wires on the bulb base. That was the problem twice for me.
