Thats all right, you can make up for doing it wrong for the last 10 years and do it correct for th enext 10 years. Just what does 11 quarts with filter mean while prefilling the filter is recommended?
Comes out right at the full line on every one of the 5 trucks I have had, can't argue with consistency.
Thats what I said because there are miss marked dipsticks, the tube is not all the way into the block, etc. I guess maybe you should read some of those web pages you link to and pay attention here you might learn a thing or 2.
LOL, you really should spend a little more time thinking about some of the stuff you post. The crank crates a heavy oil mist when it hits the oil, the mist gets shoved out the crank case vent, it condenses in the vent and you get a small steady stream of oil coming out the tube in extreme conditions, LOT of drips in others. Ever see what happens to the underside of the truck when you fill the crank with fuel?
Probably not cuz you are missing the point, same as the oil level while running. Seriously, you should probably spend a little more time in the garage instead in front of that computer from the sounds of it.
Will it hurt to run 11 quarts, no. Will it hurt to run 12 quarts, no. 12 quarts has been the norm on all of the B engines and never seen a problem with it, EXCEPT, when there is an issue with the dip stick or tube. As for using a half quart or even 2 in 5000 miles, normal. Most of these engines don't get worked enough and they all end up eating a little oil after you 150k or so on them. No big deal, just part of the mystique.![]()
Tell ya what. Read the TSB I posted above and tell me how you interpret "The total capacity of the 24 valve engine crankcase is 10 quarts plus 1 for the filter. "
Or the problems that it lists that could occur if the engine was overfilled by as little as a quart-and-a-half. Such as aeration. It says there won't be engine damage from overfilling, but personally, I prefer to keep air out of my oil.
Are the TSB, owner's manual, and shop manual wrong for my truck?
