Nah, doesn't bother me a bit when self proclaimed epxerts like you start the nay saying because they can't read it in an owners manual, a shop manual, or whatever other publication they bless as the truth. I really feel sorry for people like that are unable to think critically or outside the neat little box their world consists. You miss so much of the ricj knowledge available to those that can get beyond their limited perceptions.
Obviously its pretty new to you cuz you can't seem to grok what it means. Of course, since you read it somewhere it would NEVER occur to you to question why the flip-flop when nothing else seems to change except the perceptions. Again, thinking in that tight little mind set tends to limit your potential for even understanding the nuances.
Yeah right, :-laf all manufacturesr specify the exact parameters for everything and how it should be done. They can't figure out if the dip stick is mis-marked or the oil is really overfull so they publish a TSB to only put 10 quarts in uless you get a speciual item then you can use 11.
FYI, the oiling system is used as a large part of engine and piston cooling. Less oil IS less cooling, especially under the use these engines are designed for. Hmmmm, I guess 11 is "good enough" for you and your driveway queen trophy truck. Me, I would really like to have optimum oil (12 quarts by the way as proven by MANY people bothe here and elsewhere AND some extensive use scenarios) when I use my truck for something other than a grocery getter.
I sincerely hope you never have to go in for a warranty issue, your life is gonna a drastic turn when you figure how it really works. :{
The problem is you don't THINK, only absorb what is spoon fed to you in approved venues. So you think your info is so accurate, just what is the real source? Cummins? Don't think so when you are quoting a Dodge manual. Wonder how many times Dodge says one thing and Cummins just raises their hands and says its their problem, hmmmm? That NEVER happens, right? :-laf
Ever get Dodge to tell you what the EGT limit is? Guess that doesn't come up to often where you live. How about the the wonderful LP and its adequacy sworn to by all and sundry? How does the "official" line compare to reality there?
Oh MY!!! There are actual discrpencies documented!!! Of course, you will never hear them beacuse if it isn't int he manual it doesn't exist and you refuse to process it.
You airplane story is pretty funny, and shows just what you exhibit in every other thing you discuss. You are obviously on a mission to blame this other person for SOMETHING and prove his ideas wrong, even if it takes 9 years. It never occured to you simply stress or possibly another event is responsible did it? Maybe you oughta be looking at the guy that is doing the annuals and see what ELSE he is missing, hmmmm?
Oh yeah, my uncle is ceritfied A&P in medium to large jets, passenger and freight. Really want to know how much safety factor is built in to a LOT of the pieces and systems? Want to know the differences in safety factors from freight to passenger? Want to know what goes on in these annual inspections for differnt planes and different companies?
Oh yeah, its not in your life manual so it can't be worth while.
You definitely would fit in on the DTR, you got the attitude. :-laf:-laf
