Dipricol Boost Gauge Light Bulbs
Borgeson steering shaft
Edge EZ vs. Banks Otto mind
drawson
For all those with these Dipricol gauge. I found the right bulbs for the Dipricol boost gauge. They are mini 12 volt bulbs Part # 37.
OK now that you fount them where did you find em. I have the DIpricol gauges and would like to keep an extra set of bulbs in the glove box.
Thanks
Big D
I've looked every where for these bulbs. I'm thinking that I should buy a dozen or so to eliminate the troubles of trying to find them again:D Thanks
I got mine at a Car Quest auto parts store. But last night at Walmart they had 2 packs of them in the auto lighting section. These lights are used for floor mounted A/T shifter indicators on older Fords.
Napa should also be able to find them.
thanks, drawson
I also found out today that TST carries the bulbs. The bulb for the boost gauge and trans. temp are the same, but there is a different bulb for the pyro.
Natalie will send individual bulbs ~$2. 50 ea. I ordered one for the pyro and boost.
TST phone is 812. 342. 6741
