DiPricol transmission Temp Gauge
  • Thread starter Thread starter cosborne
  • Start Date Start Date
Don't hesitate on sportlites
In Alaska Only- Stock front bumper
C
cosborne
Guest
Ok guys... need some help. I got no paper work with my gauges and have everything about done, except the wiring to the back of the transmission temp gauge.
It has three tabs. One says B, one says T, and the other has a symbol that looks like an antenna or ground symbol? Its a "T" with some additional lines on top of it. So... what goes where? What do the B and T stand for? Two of them must be power to the gauge and the other is for the sender... but which is which?
Thanks for the help... AGAIN!
You are right about your thought on the 3 wires -
one keyed-on hot
one ground
one to the trans sender
But I don't remember which is which either. I'll take a look at my instructions when I get home, or you can contact Pricol at (714) 894-0600, they are in So Cal.
For anybody else that needs this info... I called Pricol and they were very helpful.
The "B" is for battery positive (duh)
The "T" is for the sender and the symbol is the symbol for ground.
Thanks for the help damon!
