Bseg,
I just went through the brake experience on my 2WD (’96). I found rotors from $60 to $360. Pads were $40 and up.
Rotors
Why were they from $60 to $360? Most common responses were: “I don’t know”, “Because these are the best”, “These are made in China”, “These are made in the US” and "These are made in Canada”.
One parts house stated they stocked two brands, Raybestos and those from a Raybestos subsidiary (I forget the name).
They said the Raybestos (each abt $120 US) were made in Canada. They were cast, rough machined, heated then finish machined. The rough machining relieved casting stress, and heating then finish machining was to reduce total run out and resist warpage due to heat. They came with inner bearing races, studs and the ring for the ABS brakes.
They said the Raybestos subsidiary version (each abt $60 US) were cast then finish machined.
PADS
It would seem that everyone has the best pads. Raybestos has about four different pads. From no names to their top of the line ($80 per pr).
I would think like every thing else, it depends on what kind of use you need. I really doubt that high dollar ($360 each) is the best.
I went with the Raybestos. At least they had a distributor that offered a competitive rotor and a reason for a different price. I guess I would have to say I have the best. This is evidenced by the fact that they are what I went with.
Total cost with bearings, pads and rotors was $420 (both sides).
It would be nice if those responding to your thread would indicate how they came to their conclusion.
Wayne
