[OK, second try, computer lost my entire first compostition
Last night I stopped by a truck parts place and had some 1/2x3x8. 5 inch u-bolts made up so I could eliminate my overload springs (only cost $4. 50 apeice made to order!). The project went well, and what a difference in ride!!
I knew getting those things outa there would help reduce some unsprung mass, and hopefully help the ride a little. The results were more pronounced than expected. The constant jiggly motion felt on all but the smoothest roads has diminished significantly. The secondary rebounding the axle always has after hitting big bumbs has diminished as well. On rough roads the rear tires stay planted on the pavement and the axle doesn't get as discombobulated like it used to.
Three other nice side effects: Truck sets just right now (rearend aint so high and looks way better), it feels less nose-heavy and more balanced when pushed in corners, and without the spacers there is less axle windup whichs makes smooth takeoffs even in first gear easier.
When I got done last night around 9:30 I went for a long drive. It was very pleasant and had cooled down to the 80s by then. Nothing topped cruising in my Cummins powered truck with a new attitude on a warm summer night with the winders rolled down
Vaughn
2001 Ram 2500 QC SWB 2wd, Patriot Blue/Driftwood, HO Cummins & 6-speed, 3. 54LSD, Cab & Fog lamps, Camper & Tow Pkg.
BOMBings: K&N RE0880, DD boost module, straight piped, debadged body, AutoMeter Sport Comp Boost & Pyro gauges, Amber turn signal conversion
Performance: 245rwHP on BD Dyno, 0-60@ 11. 5 sec 17/22 mpg city/hiway
11,014 miles (7/04/00)
Vaughn
